Thanks Bill. I did a little teardown analysis and it is a check valve, a little ball and spring affair. The pump on my '97 also has a ball and spring, but they are incorperated into the housing. Bottom line, the housings for the '97 and '98 vacuum pumps are not exactly the same.
As an added note, the ball is also a restriction for suction. If it is stuck open and there is a vacuum hose unattached or leaking, it could lend credence to the vacuum pump causing blowby theory.
