What makes more smoke, the BOMB or the HOSE?
First Gear gone, or is entire trans next?
Injector questions
Can anyone tell me which modification is going to produce less black smoke, the oversize injectors, or the computer module? For example:
Option one: Stage II injectors and mild computer module
Option two: Stage I injectors and higher performance computer module
Both options would give roughly the SAME power output; ie. +100 HP and +200 ft. lbs.
I want a real "stealthy" truck, that doesn't appear on the outside to be modified. I will likely keep the stock 3" exhaust (UNLESS I have e. g. t. problems), and the guages will be mounted in the ash tray if I can figure out how to do it cleanly. That way the truck would look totally stock, and sound stock, but not be stock. When I need more power, I just flip open the ash tray so I can monitor e. g. t. , and I've got an extra 100 HP on tap.
BUT ... if it lays down a smoke screen like a locomotive pulling a grade, all the stealth work in the world wont make any difference. So how do I keep smoke to a minimum while gaining 100 HP?:D
Thanks
MoparToYou
I'd stay away from any injectors above stage 2 if smoke concerns you, with the BullyDog stage 3's and the EZ box I can smoke like the steam train burning coal until the boost gets up. But, I can also do a slow start with very little smoke, not really as much fun though. You might be better off going with the adjustable fueling box and stage 1 injectors for a start, you could always swap the stage ones out to larger if your not satisifed.
Scott W.
Bigsaint makes a good point. With injectors, you're "stuck" with the amount of smoke they produce, whereas with an adjustable box, you're not. Probably the best recommendation I could make is to find a local TDR chapter and check out some other truck's smoke with a variety of injectors/boxes as only you know how much smoke is "too much" :D
Mopar back to ya :D
