Mingoglia,The truck loves Olds. It is not as steep as it used to be but you don't see many pick ups at the top. Back on topic... The lift pumps are still on restriction. This means that the tech must test pressures and restriction,fuel quality,and for signs of tampering,then call star and relate spec,s to star agent,that agent will the n make decision to send you a pump or go back and do more testing. It is up to the service managers discretion on if and how much the tech will get paid for his test time. They generally are very tight with this time fearing an audit from D/C more than whether or not the tech is fairly compensated for his time spent on required testing. I hope this helps you understand why it is so tough to get a simple job done.
Bob
Bob
