2nd Gen Non-Engine/Transmission What's my 2000 worth?
Engine/Transmission (1998.5 - 2002) Check Engine Light
Engine/Transmission (1994 - 1998) Part # and approx. price
I may try to sell my truck. Help me decide what it's worth
2000 DODGE 2500 24 VALVE DIESEL SLT+, LONG BED, QUADCAB, 4X4
Milage = 111000
Pyrometer, Jacobs exhaust brake
Trailer Tow Group, Camper Special Group
SLT Plus Decor Group
Steering mounted radio controls
Security alarm
Heated leather seats
Dual power seats with pneumatic lumbar support
6 Speed Manual Trans
3. 54 Ratio Anti-spin differential
Rear Sliding Window
Running Boards
Brand new Michelin LTX/MS Tires
Bilstein Shocks
Triglass Topper
New front brake pads, guide pins and anti rattle clips, adjusted rear brakes, changed out brake fluid by pressure bleeding, new U-joints (3), new drive shaft center bearing, new carrier, input, and pinion gears in differential, new clutch pack and axle seals in rear end, new track bar,
Oil changed every 4 to 5 thousand miles
Front differential, transmission, transfer case, & rear differential all have synthetic oil in them. All but front was changed within last four months. Front was changed 16 months ago. Cooling system was flushed and changed 16 months ago.
Asking price should be ???????? Thanks for any input
Combination of market value and book. Market value is the primary. Look through your local newspapers (or closest major newspaper) to see what they are selling for. Check out a few dealers for the same truck as yours to see what they are asking, then whack off about $2500. This should give you a good idea where to base yours at.
Sticks
Is this one of those rare 6 speed trucks with the SO engine?:confused:
OK . . . I will bite. What is a SO engine:confused: :confused: and what is special about this with the 6 speed:confused:
Thanks in advance:D
If my information is correct, Dodge introduced the 6 speed in late 2000 with the standard output engine. There were not very many of them made. In 2001 and after, the 6 speed is/was only available with the high output engine. The 2000 version of the 6 speed has a smaller input shaft to mate to the SO engine. I would think that this version of the transmission would be worth big bucks as salvage because it could be easily installed in trucks with the 5 speeds in them. (Not worth parting out the 2000 to do it though).
i have never really understood why people will pay so much more for a truck on a used car dealer lot then they will pay for from a regular everyday person trying to sell his truck... atleast he/she knows some history about it and is not trying to make a living off it!:mad:
people are pretty dumb sometimes... and why should there be 2 different book values??one from a dealer and one as a private party??how is that??!!!:-{}
Klenger is right except the 6 speeds came out in late 99. I have heard there were only 1500 or so 99's made with the 6 speed. And being as 2000 was a short production year, its probably safe to say there were only a few SO 6speeds.
-Vic
