What is your favorite BOMB on your trucks?
I am finally in the assembly stage and while everything is apart is usually the easiest time to make modifications. I would like ideas from the group so I can steal your great ideas and incorporate them into the truck as I build it. :-laf
When I finish, I want to drive the truck and not have to do anything other than routine maintenance for a long time. . The wife agrees.
I have already done: Borgeson steering, KDP, Piers Cam, 3200 gov spring, Valet Switch, Pull Cable,HD pilot bearing in Flywheel, HTT Stage II Turbo, and 3-3. 5-4" Jardine Exhaust. Pyro, Boost, and Tach are on the workbench. POD's on order.
I am planning:
Headlight and Trailer light relays,
Winch power to front and rear for receiver mounted Ramsey Winch,
2" receiver in the front for said winch.
6" rear softride springs, remove blocks (my stockers both have broken leaves and parts truck has these on it.
Softride front springs( I don't know how high but one of my fronts has a broken leaf so now is the time)
My front bumper is bent so I need a new one. Stock or buckstopper opinions?
(yes Philip, I still have that center section
I am having fun finding a stock replacement that has the holes.
I would like to add an RV deep cycle battery for camping and charge it with the alternator and optionally be able to use it for starting help. I do not know how I am going to do that and ideas would be appreciated. I was half thinking of mounting the battery under the front passenger side of the bed up against the outside of the frame rail. ????
BHAF make much difference?
I am planning:
