2nd Gen Non-Engine/Transmission Which unit bearing for my truck
2nd Gen Non-Engine/Transmission westach 387 sender specs
2nd Gen Non-Engine/Transmission Mopar belts rule the day.
I have a 2001 four wheel drive and I'm trying to determine which front axle unit bearing I need. Two part numbers are listed for Timken bearings. The first is for a 2001 4WD, 2 wheel ABS front. The other is for a 2001 4WD 4 wheel ABS front. How do I determine if my truck is a 2 wheel ABS or Four wheel ABS. Thanks.
do you have rear disc's or drums? Pretty sure the 4 wheel abs have the disc's and the 2 wheel have the drums.
J-
You can have 4 wheel abs and the rear drums. I ordered my 1998 that way. Rear disc were not yet available. Best way to find out if you have all wheel abs is to look for the sensor wire coming out of the hub area on top of the front axle.
