Going to work today I ran into problems as I was losing power during excelleration. I was running about 65 mph when I had a light jurk in the truck and lost power. This continued for about 4-5 miles on and off untill I got to work. When I pulled in at work I pressed in the clutch and it died. I tryed to start and it would not start. It would turn over. It happen 2 other times a couple of days ago where there was a jurk in at like it lost power for a 1/2 of a second. Went out at lunch and tryed to start but no luck. Went back out about 3:00 and did have it fire and run for a few seconds but died out again and would not start. I let some fuel out of the water seperator just in case but no luck. Also tryed to hand pump fuel for about 35 pumps (does this build any pressure in the system as it pumped easy) and no luck again. Then I cracked the injectors when cranking the motor untill fuel came out and still no luck. I have a head gasket leak on the back passenger side which is leaking outward. Checked oil and it looked good with no excessive amount so I don't think that is my problem (gasket leaking inward). Any ideas on where to start next? Thanks to all!!!
Dan
Dan
