2nd Gen Non-Engine/Transmission Wow!!!
Engine/Transmission (1998.5 - 2002) After market LP install
Engine/Transmission (1998.5 - 2002) Truck Dies Coming out of fuel
Got some air out of it - pushed pedal real slow this time - BINGO! Back to high and hard. Did find L/rear bearing loose. Took the axel shaft out, pulled the wedge and place the socket and bar on the nut it turned a bit more than 1/2 turn. Book says 120 - 140 ft lbs while turning hub then back off 1/8 turn. Got rid of the low speed vibrations now I need to find what the heck is causing the 60 and up. Need to check preload on R/rear and front's. I'm gaining anyway.
Thanks for the suggestion to bleed slowly.
