12 Volt Switched Source...
Poor Support from aFe.......
Aluminum Body Rocker Panels (Diamond)
Is there a location on the back of the headlight switch to get 12 volt switched power from?? Hooking up a digi fuel pressure gauge and would like to tap in back there.
TIA!
I used #17, the gauge had a seperate wire for dimming, so I used the orange wire on the headlight switch that I have other gauges tapped into.
16 psi at an idle, 11 psi WOT! :)
