Really great thread, i,m starting almost the same swap,. but with a 94 6. 5 4dr dually 2wd,. I,d really like to see the pics from the fabrication of the mounts,
what model is the transmission?
My donor is a 91, it also has an overdrive trans with a button,(i,ve no idea which model). and cruise control,. My donor engine has a vacuum pump,.
does your cruise work? does your trans have a lockup converter? did you hook the hydro boost to the dodge pump, or use the chev pump on the back of the ctd vacuum setup?
did you use stronger front springs?
Thanks
nick
pm sent,.
