93k on my NV5600 and clutch is on its way out. I tow a 5k RV only a few times a year otherwise its a commuter and I have certainly towed in 6th gear :-( I did not know that you shouldn't. I also downshift a lot and was recently told not to do that with new diesels and transmissions...??? So I have been using more brakes vice downshifting. I also have a Jacobs brake that is used almost all the time.
Sounds like my clutch is failing early, any of the things above that I am doing wrong?
Thanks for any advice.
Garth
I don't think you are doing anything wrong, as others have said. Towing in 6th is fine, but rpms won't hurt either.
I typically hold 6th if I am around 2000 or higher rpms but have no issues dropping a couple mph and running 2500-2600 in 5th if needed. I don't like towing in 6th too much below 2000 rpms on any sort of grade but that is mainly due to lower oil pressure, airflow, etc.
I run about 400/850 to the ground and will often use most of that torque in 6th on grades with the engine load above 80%. The load rarely gets above 90% in 6th or 80% in 5th at the 19-21K GCW I generally run in the summer, even on 7-8% grades.
I asked because you made a declarative statement about synchro wear with Mobil 50. I did the research, listed the Mobil fluid you referred to and then compared it to Mobil 50. I also told you of Mobil's claim of it being safe for all yellow metal synchros. I'm waiting for your explaination of supplying false info to the other members. I bring this all up because bad info is often worse than none at all and we should all exercise caution when giving advise without direct knowledge. Whether any particular fluid is factory recommended is irrelevant, when one makes a declarative statement that is factually incorrect.
I really cannot figure out what your issue is.
Neither of the fluids you listed are NV5600 compatible, simple, factual, and really hard to ignore... you know that ATF isn't compatible with all auto's too right??? And didn't you have shifting issues with it? Cold or warm fluid shifting issues means the syncro's and fluids aren't working like they should be.
Just because a trans fluid is listed as a yellow metal compatible manual transmission fluid does NOT make it compatible with all manual transmissions. You used some good transmission fluid that was designed for different transmissions/syncro's regardless of their colors.
The only factually incorrect information is your ASSumption that Mobil50 is compatible with the NV5600. It's fairly mute for you now as you run an Aisin; however, some more research and fewer assumptions would have shown you that Mobil 50 isn't the proper fluid for an NV5600, despite how well it may work in a G56.
The NV5600 is one of just a few manual transmissions that has a different fluid requirement than most. It's not a big deal, and not hard to figure out.
But that's my last input on the subject as it is obvious this isn't going anywhere.
