I just got my 2007 International 4300 with DT466 motor a couple months ago, noticed then it had a pretty fast idle, but it cranked and ran ok, but yellow engine light would go on and off. But just last week weather temps dropped and I took it on a delivery to Florida, and stopped at a truck stop on the way, and it would not crank after it had been running for several hundred miles. Finally, after some starting fluid, it cranked for few seconds. Waited couple hours and it started and idled with a very hard lope, which shook the whole truck. It idled this way for most of the trip back, but cruised good several hundred miles. Got back home, it would not start next day until it got more starting fluid, and then it idled normally. Took it to diesel shop, and no codes were active, just had a bunch of stored codes. Just reading this forum, where is best place to start troubleshooting?
FUEL RETURN CHECK VALVE?
INJECTOR CONTROL PRESSURE SENSOR?
FUEL FILTER PRESSURE REGULATOR?
OIL RAIL O-RINGS OR SEALS?
FUEL INJECTOR SEALS OR O-RINGS?
INTAKE HEATER GRID?
SENSORS FOR OIL, AIR, TEMP?
INTAKE HEATER GRID?
