I just installed a set of Laufenn X FIT AT LC01 LT35/12.50R17 121S Tires I found on Amazon for only $180 each. This is a Hankook brand, so I felt should be a quality tire. They were easy to balance, so that is a good sign. The seem quieter than even the General Grabbers that they replaces, surprisingly. With the 3.73 axle and G56 the ratios seem to work quite well with these larger tires. It puts a normal highway RPM at about 1600-1700 down about 400 from the stock size tires. Before these I installed a 2 inch level lift, new front springs, and air lift kit on the rear. With that was Freedom Offroad longer control arms (1/2"). Uppers were fine, I do NOT recommend the lowers due to my need to do an modification to attain proper Cam bolt torque, but I was able to make them work.. The rims are Pro Comp Alloys series 01, 17x9" 8x156.1mm. These I had installed on the previous set of stock sized tires, they have an offset that pushes the tires out beyond stock, but I can't seem to find the exact number. At least an inch or so (this caused me to put the fender flares on to keep the tires under the fender and legal). I had to do minor inner fender and lower plastic air dam trimming to prevent rubbing with full turns and suspension travel. I also installed sumosprings to replace the stock bump stops. These are quite a bit longer, but also softer. Pictures attached. For the control arms debacle, I have a separate post on that issues on a different thread.
