Has anyone got the scoop on the 6 speed lubricant? The owner's manual says to use the MOPAR lube only, and the sticker on the PTO cover on the trans says to use TEXACO or the MOPAR lube only. Checking with three dealers, revealed that they did not stock this or didn't know how long it would take to order it. The parts dealers within reasonable distance don't carry the Texaco stuff, and four couldn't find it in the catalogues. I e-mailed REDLINE, and they recommended using a 50-50 mix of their MTL and MT-90 which would give me basically a 75w-85w vicosity with a GL-4 rating which they say is the spec for the new 6 speed. I'm a little leary of "mixing and hoping". What do you guys think? I don't believe the bit about a trans oil never needing to be changed. Thanx, sorry for the long post, I had to get it out...
Y2K 3500, six speed, 3. 54 LSD, driftwood, everything except heated seats
