Hi, I've gotta 72 2wd long bed chevy c10 with the stock sbc 350 and 350 turbo trans. I just recently bought a running 97 dodge ram 2500 2wd with the 47re trans that I just pulled the powertrain out of to swap into the c10. I just have some questions that hopefully someone on here could help me with or maybe even find help for me:
-I've heard putting the 1993 cummins motor mounts on are best for this swap to set the motor back further on the frame. Does this sound right?
-Would I be able to build up the stock axel on the c10 for the power of the cummins? Which axel would be the best to swap?(I'd like to keep the stock 5x5.5 lug patter as I don't wanna deal with two different lug patterns)
-is there a link for the wire/sensor deletes and things you can do to the PCM for a conversion setup?(I'd really like to clean up the mess of all the wires everywhere that I don't need)
- would I only need to get stiffer front springs? ( was thinking about some airbags between the springs)
-how would I be able to get the tach and speedo to convert to the stocks gauges, if possible?
Would be great if I could find someone who has done this swap before and talk it over with them
Thanks in advance!
Posted via Topify using iPhone/iPad
Thanks in advance!
