2nd Gen Non-Engine/Transmission 94-01 Steering Wandering Count!!
Engine/Transmission (1994 - 1998) fuel pours out
Engine/Transmission (1998.5 - 2002) Ats nv4500
1999 2500 4x4 QC, always had a wander. Just replaced my 3rd trackbar. First 2 were bent and 3rd was worn out. Gone to moog now that warranty is over.
99 2500 4x4 QC Std transmission, Purple, 10 Disc Sony Changer, 285x75Rx16 BFG Mudders, Gooseneck hitch, 275lb King Klaw front bumper, Towing/Camper setup.
DDIII's, Exhaust, TTPM, Clutch, Guages are now on order.
1965 Chevy 1/2 ton Pickup, 350-350hp/2spd powerglide, PS, PB, Disc Brakes on the front, Tilt, Fuel Cell, 3. 73 posi.
26ft Gooseneck Flatbed Trailer.
1960 Farmal 340 Diesel Tractor
No real problem yet, noticed some wondering after tire change. #ad
Jeff Allan
31D 81199
2000, 3500,4x4, 355 gears Laramie SLT, BD valve Body, BD Torgue Convertor, BD pressureLoc,#14cm wastgate turbo housing, powermax 3 adjustable, stage 3 injectors, custom dual 3" exhaust with dual 4" barrel tubes behind rear tires. Trailmaster SSV shocks, ISSPRO Turbo boost, EGT gauges in piler, K&N air filter, bushwacker fender flares, black nerf bars, hellwig spring helpers, Let the BOMBing begin
My truck CAN'T wander, it always pulling to hard to the right!!!!! #ad
2001 Quad,4x4,4. 10LS,LB,Loaded,stock,... . 65 Chevelle sedan, Hella nice driver, 53 Nash Rambler Convt,1 of 653 built,[not a Metro], GM drivetrain, injection, and auto/od
Specialized FSR PRO Stumpjumper Cannondale F2000, Loaded
MTD Lawn tractor with flames
12' fishin' boat, loaded. .
99 2500 4x4... wonders. . since day one.
been to the dealer twice, one alignment, they swear it was out of alignment and it should of fixed it... . nope... but when I 1st got it the tires were hard up at 80 lbs.
Going to 55lbs / no load, it's much better... but I've driven 35ft box trucks that didn't wonder this much. My 77 GMC blazer with it's bending frame at the steering box wondered only a little worse.
My wife wont drive the RAM... maybe a good thing does come out of some of the bad things...
NO DOUBT IM A WANDERER,A WANDERER
1995 Club Cab 4WD 5. 9 SLT 5 SPEED,CAT IS MIA,TST #6 IS IN THE GROOVE,29. 5 ALJO TRAILING BEHIND.
'99 2500 4x4 LB QC
They told me it "followed the crown in the road". Yeah, right.
'99 2500 4x4 long bed quad cab auto with sport package.
My Toys
Thw wanderer. Terrible with any amount of snow on the road and trying to follow in tracks.....
2001/3500 Flame Red, QC, LB, Auto trans w/4. 10 LSD, 4x4. Ordered with everything - leather, Access Roll cover, Line-X BL, Mopar tow hooks & brush guard. CB and scanner.
NRA/NWTF/DU/Buckmasters
97 3500 CC 68,000m No steering problems no problems at all,Just that blankety-blank fuel sender unit.
Rusty Mule 97 3500 5 Speed Dually 68,000miles 25,000# POP-UP HITCH, CAT GUTTED "MULE HAULER"
Have done the alignment, track bar, and new steering box thing but at 9000 miles it still wanders all over the place--much worse than my '98 ever did.
The new steering box did help but the mechanic that did the work said it usually get worse again after several thousand miles.
'01 ETH/DEE 4x4 QC SLT 3500 4. 10
Fixes don't last very long.
95 Dodge Ram reg cab,2500,5spd,Tweaked & Peaked Cummins Diesel, MODS, K/N filter,dual exhaust 5'' tips,Lost muffler,turbo silencer, ACCESORIES,ISSPRO turbo & pyro. gauges. Shell Rotella in pan. Fleatgaurd filters. 140k. on the OD.
If you can smell this message. I Farted
