BigPapa
I know he changed tubes and o rings
I saw where he got new o-rings but must have missed where he said he replaced the tubes. Too much reading on this one for my old mind.....
A few posts back, I think you said that you were given the opportunity to install RV275 HP injectors. I think would have tried them. My hunch is that the problem would have disappeared just because the ECM would have had a much easier time controlling idle with the injector's lower flow rate.- John
I agree with John, I would have taken the opportunity to try them and see if there was any change. That would rule them out completely since the whole issue started with the injector change.
Also, just my $0.02, but I'd also put in a new set of Crossover Tubes, new O-rings, Injector Seals, O-rings, and Washers, and make sure you don't have any washers left in the holes that need to be removed. Also, check with the builder and see if you need to use the stock washers or a thinner/thicker one.
So, have you replaced the tubes or not? Let me look at the shop and see if we have a set of injectors. I think we have a set and we don’t have any VP buses anymore. If so, I can send them to you to try. I’ll let you know.
All here's reply from Flux regarding my "pop-off" question. Your thoughts...From Don
We use an opening (pop) pressure of 285 to 290 bar. The nozzle is designed for this. Actually the used ones drop to the 260 and below range often. This lower pressure has never been an issue for us, but the higher pressure settings have. Anything over about 305 has caused a few trucks to run rough at idle.
Joe,How long does it take you to change injectors ?. You should do a video as you have to be the resident expert by now![]()
Are those genuine Bosch or aftermarket? I ask, because I don't see Genuine Bosch in the ad.
If it parallels this thread it will run 5+ day as sequel plus the original release. So set aside a lot of viewing time.The video would be too short and blurry.
- John
Yes long thread for sure, don't forget about my first one that I had closed too...
Hope the "tester sticks" i have coming work...
"will run 5+ day as sequel plus the original release" I didn't forget!
Mine has always fluctuated a very little bit since new. I can't hear it but the tach shows it, it doesn't sit solid.
