amsoilman said:With due respect for you as well as any other person using a toilet paper by-pass system, anytime you add makeup oil to your system, you are putting back additives into the oil within your engine, and the oil analysis reports are going to be skewed to some degree. "One gallon in 15,000 miles" is quite a bit of oil to be adding! I have people running 20,000 miles with regular filtration (NO BY-PASS) that are getting good results back from oil analysis.
Respectfully,
Wayne
amsoilman
Respectfully,
Wayne
amsoilman
steved said:I thought the (Amsoil) endurance filters were a 20k change and the bypass filters were a 60k change (or something like that)... using their oil?? I'd have to look it up again...
steved
CFAR said:Is that dino or synthetic?
steved
Gary - K7GLD said:Just for clarification Wayne, do those Amsoil recommended oil/filter change intervals apply to ALL year diesels - or only the 3rd generation stuff?
Nate said:Gary,
Did you sleeve the center post of your filter?
Nate said:I was thinking of just wrapping some duct tape around the post.
Yeah mine is a Marine. It was only a few $$s more than the standard one.
Excellent!Nate said:To use the bigger tubed TP, I made some sleeves. I found some exhaust pipe in the garage, no idea where it came from, but it fit the ID of the Frantz perfect and the OD of the TP perfect. I cut 2 pieces, about 2. 5" each. Slide 1 down, slide an o ring down, slide the other sleeve on and another o ring. O rings don't go anywhere that way.
