My memory's getting poor - but I think in the Frantz flow test I did a month or so back, mine with what looks like the same flow orifice as yours put out 1 quart per minute...
Shortshift said:Nate, I would definitely be interested in a couple of 2-1/2" sleeves as you used to keep the o-rings from moving down the center tube. I tried your idea, but had a hard time getting the sleeves cut square enough. Would be great to have decent sleeves made.
Will see how your prototype works out for you - Thanks
Nate said:Yes that was me Gary.
Just I wasnted able to get the exhaust pipe cut square enough, so I asked my brother if he could (he's a machinist)... well instead he asked me for measurements and he'd make something.
The prototype is a solid piece, no provisions for O rings, but it wouldn't be hard to make a 2 piece design.
PVC pipe would work, but the sleeve is only 1/16" thick. My brother felt that steel was a better choice.
DaveK98 said:Guys I'm about to install my frantz and showed it to a few of my engineer friends. Both of them laughed and told me I'm going to have some tp come off and go into vital oil passages. My frantz has the screen on the the bottom (stock stuff about the size of a window screen).
I'm not really worried but still there in the back of my mind... .
walexa07 said:Don't sweat it... ..... they're just giving you a hard time. Ask them what makes toilet paper any different than the paper in their stock oil filter. Besides, if small pieces did come off, it would be taken out by the full flow oil filter before it had a chance to make it to any small passages.
Waylan
amsoilman said:Well there is a difference between the toilet paper and the paper used in Oil filters! Toilet tissue is designed to dissolve when it gets in water, paper (CELLULOSE) used in Oil filters is treated so it will not dissolve when it gets in water.
CFAR said:And this is one of the main reasons I don't run water in my oil!
