TP Filter?
I am all for the use of bypass filters but I am a bit reluctant to use TP for a filter element. :--) I recall about 10 or so years back a customer came in with motor trouble and was using a TP filter. It seems that the TP is designed to disintegrate when in water and this person living in central MN had a significant condensation issue in his crankcase. I found TP plugging the oil pickup and under the rocker covers. :{ I guess the TP is designed to disintegrate easily in water as to not cause issues in septic systems? Just guessing. The end result was the engine starved for oil and burned up. Maybe the coffee filters prevent this situation but I am still a bit leery. I suppose if you don’t short trip your vehicle you would be OK also. But I would stick with the BP filter that uses an actual element made for the job. Lets put this into perspective. Save a couple dollars on a filter or possible engine damage.
Just my two cents. Oo.
