amsoilman
Staff Alumni
Triton said:First, I'd like to tell me why you think it's SO important to filter out particles down to 2 microns or below, something a microscope can barely see? Sure... . I know cleaner is better but, if our trucks needed that much filtering..... those that don't do it must have their trucks in a junkyard by the time they see 100K. I happen to have a International 7. 3L in a Ford van that has well over 100K and it's never had anything done but, an oil change. Is it superior to a Cummins ?
I've said it before... . your average consumer will never do what we here at these forum do to our trucks. I'd bet the these forums make up 1% of the average truck buyer. A TP filter or any by-pass would be the last thing on their mind.
I'm really not trying to start something here... I'm just playing the devils advocate. I personally wouldn't use a TP set up how ever well it works. There's just no need for it. There's other by pass filter that will filter out as much or enough to do the job.
Beside everything else... . what a mess to deal with when changing the roll.
According to the (SAE) Society Of Automotive Engineers paper 881825, AC Spark Plug and Detroit Diesel Corp. performed a joint study of the relationship between the level of engine oil filtration and Engine wear rates, and found finer filtration reduced the rate of Engine wear.
Diesel and Gasoline Engine wear rates were established by building a Diesel and Gasoline Engine with fully inspected wear components and inspecting them after the test.
In both Engines, the upper and lower main bearings, oil rings and compression rings were inspected. In the Diesel Engine, the cam lobe profile and cylinders were also inspected, while the piston pin bushings, piston pins and cylinder liners of the Gasoline engine were inspected.
The total test duration was eight hours. To accelerate wear, 50 grams of AC Fine Test Dust was added, in slurry form, to the crank case every hour.
Diesel Engine wear tests were performed using filters with high efficiency ratings for particle sizes: 40 Microns, 8. 5 Microns and 7 Microns.
Gasoline Engines wear tests were performed using filters with high efficiency ratings for particle sizes of the following sizes: 40 Microns, 30 Microns and 15 Microns.
ANALYSIS
The researchers found clearances in the Diesel and Gasoline Engines varied between 2 and 22 Microns during engine operations. That means particles in the 2 to 22 Micron size range are most likely to damage Engine parts. Particles smaller than 2 Microns will slip through the clearances without damaging bearing surfaces.
CONLUSIONS
The researchers drew the following conclusions:
Abrasive Engine wear can be substantially reduced with an increase in single pass efficiency. Compared to a 40-Micron filter, Engine wear was reduced by 50 percent with 30-Micron filtration. Likewise, wear was reduced by 70 percent with 15-Micron filtration.
Controlling the abrasive contaminants in the range of 2 to 22 Microns in the lube oil is necessary for controlling Engine wear, and “The Micron rating of a filter as established in a single pass efficiency type test, does an excellent job indicating the filter’s ability to remove abrasive particles in the Engine lube oil system.
The smallest particles most popular “full Flow” filters capture with high efficiency are sized 25 to 40 Microns, depending on the filter brand.
I’m here to tell you the Amsoil brand “by-pass” oil filter achieves high efficiency. For particles of 2 Microns and greater, they are 98. 7 %!
Their “Full flow” oil filter achieves high efficiency for particles of 15 Microns and greater. In fact, its efficiency for 15-Micron particles is 98. 7 percent. The tests I am referring to is the ISO 4548-12. Together, the “By-pass” and the “full-flow” filters offer significantly greater protection than that of a conventional filter system.
This is the parameters for the ISO-4548-12:
Testing Standard
The ISO 4548/12 multi-pass test is a widely accepted industry standard test used by OEMs for the purpose of evaluating and comparing the efficiency and capacity of liquid filtration products.
Test results are an average from the testing of three product samples in accordance with ISO 4548/12 specifications.
The ISO 4548/12 specifies ISO 12103 test dust. Test data reported at 25 psid terminal restriction point.
Wayne
