when i turn my key to the "run" position and wait for my glow plugs to kick over my battery voltage stays pretty low, somewhere between all the way dead and 14 volts. when i turn my truck over the voltage goes almost to nothing, but does start. for the first 3 minutes of idle my voltage flickers every so often from about 11 volts to 14, and so forth until it stays at a constant 14 volts. at first, i thought it was due to the cold weather (moved from TX to pa this last June), seeing how back home we don't really get cold weather.
i then drove down to advance auto where they tested my alternator (which was bad) and they also stated one of my batteries was completely dead! i say what the heck, everything replaced. after everything was seated and back to normal, i started my truck and i was having the same problem all over again! (note this was after i paid my 315 bucks!) the guy at advance auto then went on about my voltage regulator being bad, and after further research he said the "ECM" (which i am guessing is the truck's computer) controlled my voltages and that i would need a new one! does this guy know what he was talking about? has anyone encountered the same problem? thanks in advance for all the info, this website is great!
