AH64ID
AH64ID,
Here is the degree symbol if you want to use it °
Thanks. .
It's funny, I take the time to get the ± sign, but always use * for deg...
AH64ID,
AH64ID,
Doh... no keypad on the laptop!
I had forgotten all about ASCII language...
Much to PC12's surprise, but not anyone else, this is an amazing tow turbo.
There really isn't any getting under it, at least not with smart driving (and no, unlike what your thinking right now I'm not talking about shifting at 3K rpms to keep the upshift rpms high)...
PC12Driver: Hopefully that's enough for you to be satisfied, but somehow I doubt it.
I'm both a fan of and a maintenance test pilot for the Apache.
Thanks for the personal attention. However, since my point all along was that the smaller of the three Garrett offerings would be better suited for towing, not that the middle one wouldn't work for towing, there really isn't much for me to be surprised about in your findings. I don't think I ever stated that I didn't think it would work as a towing turbo, just that the Stage 1 would work better. I still maintain that if the Stage 2 is as good as you say it is, then the Stage 1 would make an outstanding towing turbo for the slightly modified crowd.
Sounds like you can get under it though. Above what RPM do moderate throttle changes not result in a cloud of smoke?
Also, how much effect do you suppose your cam had on your results? Seems like getting away from the high drive pressure to charge pressure ratio from the tiny 9cm housing on the HE351 would really complement the increased overlap from the aftermarket cam. Do you think your results might be a bit more dramatic than the stock-cam crowd? For example, my cam gave me 100-200 rpm of my powerband back with my larger turbos.
It's pretty clear from these and other comments that you took this discussion personally, and I think any of your subjective findings should be interpreted with that in mind. And like the "surprised" thing, there really isn't much for me to be "satisfied" over, since, again, none of your findings have anything to do with my underlying point.
And the Apache question was to see if you had experience flying turbines, with the hope of working in some parallels to turbo physics into the discussion. But that's a moot point now, since your emotional attachment to this has killed any interest I had in this thread.
I'm glad your turbo works for your application. It's good to see that internet hype does work out occasionally.
