So I replaced the blower motor in the 99 this week. Turned on the a/c one day and nothing. I checked for continuity at the plug behind the glove box and nothing. Checked the resistor just to make sure and it tested fine. Finally found a motor in stock at the local auto zone. Part number is PM3788, and its made by VDO (not sure if its the same VDO as the gauges or not tho). It didnt have the same plug so I had to cut the old end off and splice the plug on the new motor. Here's a brief overview.
Pic of underneath where the motor sits behind the glove box. There were three phillips - 5/16 - 8mm screws holding it in. I found a short extension, a universal joint, and the socket helped get the one in the back out easily.
Once the screws are removed and the harness unplugged it comes right out. I wont show a photo, because Im just a bit embarassed of how EXTREMELY nasty the fan was.
Next remove the tension clamp at the tip in the middle of the fan with a pair of needle nose pliers.
Had a friend help me get the fan off the old motor. I held the fan while he took a punch and drove the shaft down and out of the fan. Took 3-4 hits and it was all apart.
Here are the three pieces pulled apart. I helped my brother replace one of these on his 98 a few months back and his didn't have the bottom "shell" with the foam. Im guessing its to keep any noise from vibration or squeaking down. *note: when we bought his motor from oreilleys, it already had the fan part on it. I was unable to locate one here local now that has the fan already installed*
The box & the new motor.
The old fan (after a VERY thorough cleaning) installed on the new motor. Install is reverse of the removal.
Button everything else up just like it came out (DONT forget to plug it back in... you'll have a brief Oh $#!t moment when it doesn't come on)
Here's a shot of the switch resistor... Its to the left and slightly towards the firewall from the fan. Just two phillips head screws and the wire harness hold it in.
Another note: When you get it ALL back together and are ready to test the system, don't forget that the mode (floor, face, defrost, etc) is all controlled by vaccum. You won't have vaccum unless the truck is running. Had another Oh $#!t moment when I tried changing the mode without the truck running. I tend to forget the simplest things like that.
Hope y'all enjoyed.
Craig
Hope y'all enjoyed.
Craig
