well
The company I work for has INSITE I havent done it yet but im gonna I can fax you guys copies of my info so your steeler can look at them and find out wear to go you must use INSITE and you connect inside the cab there are two ways to do the mod the most easy way described above and a more involved way that uses your "coast"/"resume" switches for cruse another neet thing I have found out is that you can wire your exhaust brake to work with your cruse control you program the ecm for a max MPH over set cruse MPH and when the speed reaches the max set the exhaust brake will activate (the only down fall I see is only 1 max speed)this feature would only work in cruse and I believe you could still use the E brake the normal way O YEA and im gonna have the guys at work set my max cruse speed at the max value(cant set mine over 90mph)O well Im gonna try? the info that I have is called "Cummins ISB guide for body builders" its about 75 pages I can fax them BUT I would rather fax em to some one who could post them on the web for all to view and print ANY takers??????? I will be gone for the rest of the week so I will check in later!
Jason
Jason
