combination turbo timer/high idler?
New XM Radio
air horn opinions
My first Cummins is on the way, I should have it within a few days. I want this truck to outlast me, and want to get both a high idler and a turbo timer as soon as possible. I've seen high idlers where you manually set the idle when you want it to go higher, and I've seen some that idle higher under certain conditions, like the truck is in neutral + coolant temp is below X degrees + whatever. I've also seen turbo timers where you set it to 2 minutes, 5 minutes, whatever, and it runs for that long, or other ones that run until the EGT drops to a certain point then shut off. I'd like to get the "deluxe" version of both of these, and I think it would be simpler (and cheaper?) if I could get both in one unit. Does anyone make a product like this, with all of the "automatic" features, as opposed to manually setting your idle and manually setting the amount of time to cool the turbo off? If not, what would be my best bet for an "automatic" type turbo timer and a high idler?
