2nd Gen Non-Engine/Transmission coolant by-pass hose!!!
Engine/Transmission (1994 - 1998) 24 valve exhaust system onto 12 valve
Engine/Transmission (1998.5 - 2002) oil presure gauge
Hello,
I have a 1996 Dodge 2500 CTD with the auto transmission. I was wondering if anybody has ever plugged the by-pass hose? In the manual it says its just for removing air from the system. theres a one-way check valve that opens but with the engine running its closed letting all the coolant go through the t-stat. I feel the hose and its very hot. Iam wondering if the check valve is stuck open. I live in alberta, Canada and winters are cold. I was wondering if i eliminate this if it would bring my operating temp. up a bit??
Thanks.
I doubt it, that hose is pretty small. If you aren't towing you can remove your fan for the winter. If that isn't enough block the radiator, starting with a small area and progressing up until your engine gets to the desired temp.
I wonder if you can make something like this to help?
From Geno's Winter front grill cover for 03-09
