Chris, if you just need to replace the plastic that frames the instruments on the driver's side, you need to lift up the flap that houses the 12 volt power take off just to the right of centre, near the top. Remove the small black cross-headed screw that is revealed. Pull the adjuster arm on the left of the steering column and pull the steering wheel down to its lowest setting. With your fingers or a flat blunt blade in the joint, press downwards and outwards along the top edge of the plastic and the clips will release. Do this all around the plastic until it falls away. A two minute job when you've done it too many times! If you wish to remove more of the dash than that, I have no experience. Have fun. Nick.
