I priced out the 2015 upper hose and the cheapest I found it was around $65. I priced the Gates 20957 hose and they are around $17 each. That's the direction I'm going to go. You cannot (by my estimation) remove the plastic part wye from the stock hose as I believe the plastic part is longer than the aluminum part replacing it. Plus, I'll keep the stock part just because I can always use a backup.
I am wondering if Ill need to reuse the metal support ring that is on the stock hose. It does come on the 2015 model too so it looks like it might be a necessary part but I'd have to make sure it doesn't rub a hole in the new hose if used. Any thoughts?
I installed the billet wye this last weekend. It went smoothly except I thought about using the old hoses as suggested but when I looked at getting that plastic band off the ends of the plastic wye, I thought better of it and just cut the Gates 20957 hoses that I purchased. So now I have a backup that I'd better not need.
The clamps that come with the Black Market part are pretty small and I couldn't get one to clamp over the hose and the barbs. Not sure why one of them was this tight and I got the other one to work. Anyone else with this issue? I wish I could have used the other t-bar clamp that came with the part.
I lost a quart or two of coolant so I had to buy the liquid gold (purple really) from Dodge and refill the reservoir as there is no conventional radiator cap that I could see. So far, so good no leaks! I did overfill the reservoir by maybe an inch or so. Is that a problem or will the system bleed out the air and use what it needs? I can pull some out if need be. All in all, it took me about 35-40 minutes and I did reuse the metal support loop that was on the old hose.
We will see how she does in the heat when I tow the 5er again!
I installed mine last Friday evening, no issues with the supplied clamps. I also had an extra T-Bar clamp I used on the outlet on the motor. No leaks, or issues of any kind. Nice to finally not smell coolant in the cab. Blackmarket Performance says the lower Y is the same as the upper, so I'm going to change the lower Y at some point in the future so I don't have to worry about that stranding me in the back country.
Did you use the stock hoses without the plastic wye? I wonder if the Gates hoses were a bit thicker? I will also plan on changing out the lower wye as well. I have heard that the lower wye does not have the failure rate of the upper hose.
