I've been getting the P2121 code for awhile now, did the obvious and replaced the pedal but it came back. Today I decided to dig into it with an article I found to check the voltage.
With my scan tool the voltage is within spec at all tests however when I go under the hood and wiggle the big harness up by the firewall the voltage readings on apps start bouncing and check engine chime starts going crazy. It seems to be the wires that go down towards the engine and trans. I wiggled the wires down by the ECM but didn't notice any jumps in the voltage readings or the check engine chime.
I guess it's time to disconnect that harness and inspect the wires.
