Early 07 with 5.9 Hard starting when warm
Firestone Air Bag Suspension Kit
Fan nut size
07 PU hard to start when warm. No codes and starts fine in the morning. After running and getting up to temp the engine has to spin over a lot to fire up.
Welcome!!
Just cranks, sputter, smoke? Please explain some more?
edit= at the bottom of the page are some similar posts that might be a help...
It just spins the engine and acts like its not getting fuel. If it sits long enough to cool off it starts right up. No smoke or sputtering. Is there some sensor or something that when warm could stop the fuel. I changed the filter and had the shop look at it they said my pump and injectors check out very good and just to run it until I get a code. I just don't want to get stranded some place.
I dont know what to say, you prob checked the right stuff....electrical or CP3 comes to mind.
Its my bedtime ,... hopefully some 'smart' night owl will chime in soon!
Wish you well!
I know this is a different motor but I had the same exact thing happen on my 3.0 VW diesel last week. Started fine when cold, when warm would only crank, no fire. Let it cool down again, started just fine. Put a good scanner on the car, read some codes, looked at some real time data. Turned out to be a cam position sensor went bad. $46.46 and 6 minutes later, all done.
