Is the TDR forum always kinda lean on love and sunshine?
Re. effectively reducing the leverage the spring bars have to shift trailer weight. I don't agree. Moving the hitch shank deeper into the reciever doesn't change the geometry of the tension bars, ball and tongue.
I am on diesel forums out of love for diesel trucks. It is entertaining and educational at times. Absolutely it is a nice looking truck and you are braver than I for trying out a 1st year model/engine. Sometimes the 1st year is the best year. I do hope you will post more stories and experiences with the new engine for our enjoyment and curiosity on how the new engine is doing.
As far as the distance to the hitch receiver to the hitch ball I suggest we look at it a different way in a thought experiment. Put a long solid bar into the hitch receiver. Lets make it really long. Now imagine standing on the end of this long bar. The long bar is simply a lever. The fulcrum is the rear wheels. Now imagine your weight on this long lever lifted the front wheels off the ground. Just like trailer tongue weight alone does. This is a standard hitch. The length we need to lift the wheels off the grounds depends on if you or your significant other stands on it. (I assume you are different weights or she has a heavy purse...)
Now we add the WD hitch spring tension. What exactly does the spring tension act on? We need to add the other items to make this work like a ball (hinge) and another fulcrum specifically a set of 'trailer' wheels to the above example. You see there is a second lever set at play to counteract the above lever of you standing on the bar to lift the front wheels. The lever for the weight is still the same, but, we change it up to illustrate the WD hitch operation.
We start at the front pickup wheels that are now the fulcrum turning into a lever that comes to the back of the truck and continues to the trailer ball at a specific distance. (The rear wheels are not part of the 2nd lever set example.) We add the hinge (trailer ball) and going back the WD torsion spring attach point and a distance (2nd lever) to the trailer wheels. Trailer wheels being a second fulcrum. This second set of hinged spring loaded levers is what counteracts the simple weight lever.
So you have a simple weight lever using the pickup's rear wheels to lift the front wheels off the ground being counteracted by two other levers and a spring. The spring tension wants to lift the front of the trailer by pulling down on the lever (at the chain attach point) going to the trailer wheel fulcrum. Yes, down. The other lever between the
front pickup wheels and the hinge (ball/front of springs attach point) is also pushing down on the front pickup wheels and literately lifting the rear wheels as just a point of the lever. Imagine if you had a really loose hitch receiver you would see the top rear most part of the hitch pinned to the top of the receiver and the bottom toward the front of the truck would have the hitch pinned to the bottom from this lever set. (Of course weight from the trailer may overcome this visual example.) It is literately torquing the front wheels back to the ground by lifting the rear wheels with the spring tension.
If you had extreme spring tension and no weight the rear wheels of the pickup would be off the ground. The trailer tires and front pickup tires would have all the weight.
So changing the distance of the WD hitch ball closer to the rear bumper is changing the length of two separate lever systems. Sure it is taking the weight lever closer to the pickup and reducing it's effect. It is reducing the length of the front wheel to the trailer ball lever. By reducing the weight effect you are reducing the WD's torque to the second lever system that transfers the weight to the front wheels. Further you are reducing the lever length to put weight on the front wheels. the 2" shorter change is reducing the WD hitch setup's ability in two separate ways.
A bunch of math and measured lengths later you could determine the exact change that 2" shorter levers comes out to. Like this example and diagram.
The 5th wheel and GN hitches eliminate the lever mess as the weight is all over the rear wheels.
Re. 30mph and what is most restrictive. Well, I don't know. At 30mph the amount of air flow is not high, so I figure that's what is limiting cooling. Altho there is other coolers forward of the radiator, AC, oil, transmission and intercooler, they shouldn't restrict air flow too much. People look at a heat exchanger forward of the radiator and think that it's blocking all the air flow and that's wrong. It's reducing some of the air flow, but not blocking. The high pressure zone at the grill and the low pressure zone behind the radiator will still ensure lots of air flow. Static high pressure will get around any obstruction. The extra heat exchangers also don't significantly increase the temp of the air hitting the radiator. This is because the radiator is dumping huge amounts of heat and everything else is orders of magnatude less.
Re. fan doing some good at freeway speeds. I'm still surprised by this, but you guys have seen it so I'm happy to accept it. Fan ratings are hopelessly optimistic because the fan blades are too close to the radiator for the air flow to efficient. What happens is in the absense of "stators" to turn the spinning airflow into longitudinal flow. 3000-5000 cfm is a common range for aftermarket fans, using those hopelessly optimistic #'s. Lets say the hopelessly optimistic # for the Cummins fan is 10k cfm. Assuming 9 ft^2 of radiator, 60mph works out to 427k cfm, 2 orders of magnatude higher. That's why I'm surprised that turning on the fan at freeway speeds is helpful.
Re. burned up black mark of charred asphalt. If there were serious mountains in my part of the country I might have reconsidered. The truck does 1/2 of the daily driver duty tho and I was highly motivated to get the 3/4ton truck out of the daily driver business. If, when the day comes that the Ecodiesel is laboring up a steep grade, I'll just go a little slower. All decisions have trade-offs.
Electric fans are CFM rated freestanding - that is without any radiators or other restrictions. I recall the wimpy e-things top out around 5000 CFM freestanding.
Radiators are restrictive. Bug screens are a known restriction. A radiator hung out the window at 60 MPH isn't going to have 60 MPH of air going through it. Air's escape path is also a big factor. Most of the air that goes thought the radiator stack goes under the vehicle. The air dam under the front bumper makes a difference to a low pressure area under the vehicle.
Yes, you get some airflow at 60 MPH. There is a point on some vehicles where fans are a 'windmill' restriction as the fan with the clutch kicked out is spinning faster than engine RPM from airflow. Downshifting to higher RPM can move more air. One reason you may need a lower gear to keep cool with high loads.
Long time ago I had a Trailblazer SS that wouldn't keep cool. 395hp/400 TQ in a little SUV and a 21" fan. I took a wind speed meter and measured MPH using a grid to average airflow. Hood closed 0 MPH in the garage to eliminate wind effects with the AC condenser, radiator, and engine in the way I measured 10,000 CFM from the mechanical fan. I tested RPM all the way up till the fan belt started to squeal. It had an EV fan I could force to go 100% lockup and then a friend to hold higher RPM steady. My conclusion is that electrics don't stand a chance at moving the amount of air a mechanical fan will. Further, although there was plenty of airflow, the radiator was too thin and couldn't use it all. The solution I helped a aftermarket company bring to market was a ~1.5" thick radiator vs. the factory 1" unit.
As a popular mod on GM 6.5 diesels is to drop in a improved 19" or 21" Duramax fan and I had an extra 21" Trailblazer SS fan sitting around... It cools 2x the HP and the same TQ of course I tried it. The first grade with the windows down and heater on high I learned something about blade pitch. The 10,000 CFM fan did not have enough airflow for the IDI diesel. The 6.5 GM bodystyle has an airflow problem with plenty of radiator.
So mechanical diesel fans pull way more than 10,000 CFM. Dodge fan sizes may vary, but, pitch and driven RPM make a difference.
I am not sure I could see very well over a 9' tall and 9' wide radiator.
CAT?
