Hi guys,
Installed my edge comp yesterday and none of the lights come on,
ARE YOU SURE YOU TAPPED THE RIGHT FUSE?? there's 12 volts checking between the black and red wires into the comp
WHAT DID YOU DO SKIN THE WIRES ON THE COMP HARNESS TO SEE IF THEY WERE POWERED?? and a check engine light on the dash.
IF THE CEL IS ON YOU HAVE CODES??? DID YOU TRY THE THREE KEY THING??? No codes.
YOU PROBLY HAVE CODES PRESENT GO TO AUTOZONE AND HAVE THEM CHECKED Soon as everything dries off around here I'll get back back out and check my connections(soldered the pump wire)
GREAT IDEA but it seems to me that the least the darn thing could do is light up.
NOT LIGHTING UP SHOULDNT HAVE ANYTHING TO DO WITH THE FP WIRE OR ANYTHING THE ONLY THING THAT EFFECTS THE LIGHTS ON THE COMP DISPLAY ARE THE POWER WIRE GOING TO FUSE BOX AND THE GROUND WIRE GOING TO BATTERY. . YOU SHOULD BE ABLE TOO UNHOOK ALL CONNECTIONS BUT THOSE 2 AND WHEN YOU TURN THE KEY ON IT SHOULD LIGHT UP... NO POWER GAIN BUT IT SHOULD STILL HAVE POWER TO IT----NOTE I THINK THIS IS HOW IT WORKS NOT POSSITIVE ON IT> Aaghhhh! Anybody have any ideas I'd appreciated hearing them.
Jerry
98. 5 QC LWB Emerald Green. . Attempting to bomb
