Enhancements
Bhaf
2 110 plugs ?
I'm a new owner of a 2001 Dodge diesel,bought in MAY. I pull a 5th wheel trailer which weights 12,000 lbs. I have just completed a 12,000 mile trip around the country averaging 12MPG and was very pleased since the truck is stock.
I want to improve preformance but don't know where to start. Thought I'd start with 4 inch exaust and jake brake. Later would like to increase Torque,
HP and MPG without destroying the drive line.
I would appreciate comments concerning these enhancements or others maybe more appropiate.
I used overdrive about 90% of the time on the trip
and cruised at about 2000 RPM at 60 MPH. Am I asking for trouble using O/D this way?There was very little shifting going on and know hunting since I controlled it with foot feed.
RMoorman
2001Dodge, 2500 Quad, 4:10 rearend, automatic 2WD.
White with Stainless steel running boards,Rhino bed and vented tailgate. K&N filters.
Reese 16K 5th wheel,98 Automate 32ft.
Get a edge ez. It can be unpluged if you need warrenty work. and it has good power for the buck. My mileage went up about 2 mpg all the way around.
Yes, check out the link in bob's reply before you add an exhaust brake. I would spend $$$ fortifying the transmission before anything else, then the brake, then an ez edge. Exhaust change won't give much/any hp, but it'll sound better (depending on your point of view).
Been reading here for couple of monthes, started with a full set of gauges (exh temp,turbo,eng/trans temp,gas pressure). I used Westech and like them.
Next lost the muffler with replacement pipe from Geno's--just testing of course :D .
I think EZ will be next addition with larger
injectors to follow.
Have started saving for the New Trans from Bill Konaloy (sp).
My 2-cents worth... ... J. B.
An PowerEdge EZ and 275 RV injectors are a great towing combo. A good set of gauges is a must if you are going to start BOMBing. With this combo, you get increased throttle response with a big load, the mileage should improve at least . 5 mpg and your EGT's should stay manageable. I pulled a 6% grade in very hot weather last August, never had to downshift out of fifth gear and saw max EGT's of 1050. I highly recommend this combo and it can be had for under a thousand bucks. Go for it, you won't be sorry.
RMoorman,
The DTT torque converter and valve body upgrade alone raised my fuel mileage by 1. 5 mpg. You can't even imagine the difference between it and stock.
I really appreciate the responses and realize I have a lot of homework to accompolish. I am extremely behind in diesel "lingo" and tech talk.
I'll continue to read postings and hope to pick up
enough so i can carry on some decent chatter with you pros.
Thanks,
R
Moorman
Edge ez
SEmerson,
Can you recommend where I can obtain information
on the Edge ez. Where would you suggest buying the Edge ez?I'd like some tech info before buying the unit. Thanks
RMoorman
