OK in short. Noticed the grinding sound too late. I've got one pad worn through which has severely grooved a rotor.
No biggee. Just pull the rotor and have it turned or replaced. Right? sort of.
Do I really have to beat the wheel studs out of the hub to get the rotor loose? Wow! Seems scarey... is it?
Seems like if I have to go to that much trouble to replace the rotor I may as well go for the full hub/bearing replacement as well (from http://www.quad4x4.com/DodgeParts.htm)... .
In short... before I dive in and tear my truck down for weeks on end to "beat" the rotors free from the hubs... . anyone have some encouraging tips/techniques ?
How would a normal humanoid turn these rotors? I've always been able to take the disc down to the local NAPA (or whoever) and have them turn it. Not gonna happen if I show up w/a 60lb rotor stuck to the middle of the disk... is it?
Thanks in advance. Eric
