SnoKing
Because the correct tool is 3/8 drive and much shallower which allows less angle on the universal or better yet allows the use of a wobble extension. Being 3/8 helps hold the gorillas at bay.
What he said ^^^^^! Snoking
You want a picture of my small collection of 1" drive sockets?
I think the 1 1/8" is in the truck box, as that is what fits the anode in the trailer hot water tank. If I recall mine is a 12 point.
SNOKING
Curious, why not a 1 1/8" 6 point socket?
I agree!!!Not sure why Genos only offers the 29mm for the job ,certainly not the right socket.
Can you buy a 1 1/8" 6 point socket for $6.95. And it would weigh twice as much and I am watching my weight!
Snoking
Better yet why not a 28mm 6 point better fit ,worked awesome when I used mine. I certainly wouldn't be putting a 1mm bigger socket on that filter housing. Have to believe thats some of the problem guys are having with removal. Thats putting a socket thats just over 1/ 32" larger then it needs to be.
I keep forgetting.......you 3500 SRW guys do have to watch your weight.Can you buy a 1 1/8" 6 point socket for $6.95. And it would weigh twice as much and I am watching my weight!
Snoking
I assumed you the man with all the cool things would have a 1 1/8" 6 point socket.![]()
My 1 1/8" is a 12 point 1/2 drive. It fits tighter than the 29MM from Geno's. I sent a message to Genos' about them selling a 29MM socket when I should be a 28MM. I will report back on what they have to say. SNOKING
I got out my digital caliper and measured 28MM on the hex. SNOKING
The difference is right between 1/64 and 1/32", that difference will NOT strip using a 6 point socket.
Maybe you will explain why, when there is always the chance of a larger socket slipping OFF ,and taking some of that plastic off on its way, and over time will eventually strip the head. Maybe you have an explanation for the ones that are stripping that filter cover, IMO its got a lot to do with a 29mm socket .
IMO get the right tool for the job.
Not sure what you are getting at, "I" use a 1 1/8" 6 point socket It fits good and have zero issues doing so. My 2011 HO had the same housing so at that time it was recommended on here to use the 1 1/8" 6 point. Mine is an short 1/2" impact socket I keep in my truck toolbox. I use a 1/2" wobbly on top of the socket with a long extension and a 1/2" ratchet. I am guessing those having problems are using 12 point sockets.
My 1 1/8" six point deep socket has served me well since 2003....when I bought a RAM 2500 Quad Cab 4x4 Sport w/305*555 & NV5600. From the "What it's Worth Department"......Between the '13 I previously owned and my current '14....I've performed 14 fuel filter changes with this setup and also have zero issues.Not sure what you are getting at, "I" use a 1 1/8" 6 point socket It fits good and have zero issues doing so. My 2011 HO had the same housing so at that time it was recommended on here to use the 1 1/8" 6 point. Mine is an short 1/2" impact socket I keep in my truck toolbox. I use a 1/2" wobbly on top of the socket with a long extension and a 1/2" ratchet. I am guessing those having problems are using 12 point sockets.
Correct!!We are apparently not on the same page, you replied to me when I stated the problem could be the difference between 28mm and 29mm . The difference is over 1 /32" . You are talking about the difference between 28mm ,and 1 1/8" , yes .022 . Less of a chance with 1 1/8" then using 29mm, but IMO if you are having to buy a socket, which I did, then go 28mm 6 point. It makes no difference whether its a short impact or a conventional . I only had a 1 1/8 12 point, that I used for the first filter change. IMO ,and others its playing with fire using a 12 point.
Why some think it needs to a short socket in 3/8 drive escapes me, like the one from Geno's , which is the wrong size .
" between 28mm ,and 1 1/8" , yes .022 . Less of a chance with 1 1/8" then using 29mm, but IMO if you are having to buy a socket, which I did, then go 28mm 6 point"
Agreed, but I would still buy the 1 1/8" because there is more of a chance to use it on other things. As gsbrockman shows both sockets are recommended.
