gauges
Hood Emblem
Installed Valve Body
O. K. I've decided on the manufacture for my first set of gauges. I'm looking at EGT, Boost, and trans. Thinking of diff gauges another possibility. Should I get just a trans gauge, or should I get a diff gauge also? What temp range should I look at getting? 100-280, 140-320?
How about boost? 0-15, 0-30, 0-35, 0-40? To many decisions, and not enough quarters available to toss. :confused:
Paul
This should be my final decision on this topic, unless I change my mind again.
For your oil temp guages, use two sending units and a switch to monitor both. Once you have a baseline, you will know when you will want to be looking at either one or both and what to expect.
For boost, more (ability to read higher) is best. Forget 0-15, to low period. 0-30, not much space for improvement (more mods to make more boost, it happens).
0-40 on the boost gauge for sure. With a 0-300 AT temp gauge you can add just add another sender and a switch and monitor intake temp. I'd go for a fuel pressure gauge before I would differential temp. In fact I'd go for fuel pressure before I would boost, it's very important. Want to borrow another quarter?;)
Here's what I use and am very happy with the results, have not had one problem. Trans temp runs about 120 on freway and 150-180 in traffic and towing. Boost reaches 31 when I get on it. About 1000 on EGT up long steep hill, on it. I changed my bulb covers so they match my dash lights (blue). Used the pillar as a replacement not a cover. Well good luck. I will be getting a Fuel Pressure gauge next.
Go with the 140-320 temp gauge if you are putting the sender in the line going to the cooler. For readings from the pan the 100-280 would be fine. My sender is in the cooler line and I have seen it over the 250 limit on my autometer. This is on a stock truck not towing anything. It is lame not knowing how hot it realy got. You just now it got over 250. :(
AutoMeter has a batch of pyrometers in circulation that condensate internally on the lens. I would assume that the other internal parts are wet as (a) well. :(
Dr kayak
I have my temp sender in line and have never seen it that high wow, I even drive in LA traffic stop and go and it only reaches 180 or slightly over if stopped for a real long time. For the fogging problem I guess I've been lucky, only happened once on one gauge and never again since. Any way good luck on your decision. :cool: :D :)
