I've often wondered, while laying down at night staring up at the ceiling fan... why, oh why cant MFG's just make the core removable by taking out 4 screws of an access panel and pulling it down, or out, or whatever from the heater box. I mean... if you've ever looked that the complex design of heater boxes... would it be impossible to make the core fit in there in such a way that it can be removed without pulling the entire interior out and having 50 sheet metal screws laying around and laying in a floor board in contorted positions trying to see why some electrical connector won't pull out?
Imagine... . "Drain Coolant. Disconnect heater hose quick connectors using special tool 83-5766T. Remove glove box door. Remove 4 screws to heater core access panel. Remove core being careful not to drip any coolant on interior surfaces. Replace in reverse order. Connect hoses. Fill system and check for air. "
Must be impossible. Rant over.
