Hello all,
I have been talking and reading trying to decide my "next steps" for the perfect setup for “my” truck. Some of this text is from a Torque Converter post of mine if it looks familiar to you.
I thought I would try a more direct question to get the benefit of some of your experience with High Altitude bombing.
My Goal is to “get to or approach” the power of some of the TDR members who have let me drive there trucks, 350+ HP range (Thanks BOB, Mike and Kevin!) and still have control over the smoke when I am in heavy traffic on a warm day at 5500 feet without that eggshell under my foot felling.
I’m learning and want to learn more like, Max injector size with PDR HY35 or other suggested turbo for example.
My truck 2002 CTD, 47RE-Auto, 3. 54 gears
Gauge's DiPricol fuel press, boost 0-35, EGT, Trans Temp.
4 inch exhaust.
BHAF with SS heat shield.
EZ installed.
275RV new in the box - un-installed for after transmission work.
Making arrangements for DTT 89% "H" with Tow Valve body.
Usage is 95% daily driver some towing in the 8500lbs range in the mountains.
Because I live at 5K feet and drive between 5K and 6. 5K+ feet daily and a great deal of Denver traffic, smoke control is important to me.
I have been thinking PDR HX35 but am unsure if the $650 includes the exhaust housing? Either way I am unsure if I should get a 12cm, 14cm, 16cm waste gated or not?
I will probably want try larger injector down the road if smoke is manageable with the 275's and EZ maybe even more or different electronics and a cam down the road after saving some more $$'s
If the turbo PDR HY-35 will support 350HP what boost numbers are we talking with 275's or larger mid-range 80hp type injectors?
am I on the right track? how did you Prioritize purchases?
Also are there any books that explain turbo airflows, how different injector effect turbo lag, and how to make this performance parts balancing act work the first time?
Thanks Jim Johnson
4 inch exhaust.
EZ installed.
Thanks Jim Johnson
