B.G. Smith
Just did my test drive and the brake drums stayed cold!!! But..... that is with the shoes backed way off and the ebrake cable very loose. So now I will start adjusting them.
Without rehashing all of the drum bake adjustment threads (I've read them all), do you guys have any special tips?
I plan to leave the ebrake until last... adjust the shoes, then after my pedal comes back up and test drives show no excess heat, then I will adjust the ebrake cable... does that sound reasonable?
That is the right sequence, if you adjust the e-brake first it will be too tight when you adjust the brake. Everyone has their own method, with rears off the ground I adjust each wheel until it is difficult to turn then back off untill it's free, usually 5 to 10 clicks. bg
