I am not jumping to judgement Tomeygun - I have looked at a lot of side step mounting systems recently (the usual investigation prior to purchase) and they mostly consist of 2-3 plates mounted to the bodymounts and/or body. Four tubular supports have the capacity to be much stiffer (especially when you consider the supports and main tube are all one welded assembly). It depends on the mounting at the frame - Jungledave mentioned some of the plates going up and over the frame, and the rear support in the picture appears to go to both sides of the spring perch. There is a lot of promise here, but I will still need to see it in person or see something official from Mopar that says they will hold the weight of the truck (even a Hemi). At that point it would be a must buy - talk about side impact protection!
