How many Miles on your dodge 24V?
How many Miles on your 24 valve?
  • 0-10000
    Votes: 123 4.6%
  • 10000-25000
    Votes: 208 7.8%
  • 25000-50000
    Votes: 330 12.4%
  • 50000-75000
    Votes: 365 13.8%
  • 75000-100000
    Votes: 382 14.4%
  • 100000-125000
    Votes: 341 12.9%
  • 125000-150000
    Votes: 271 10.2%
  • 150000-200000
    Votes: 329 12.4%
  • 200000-250000
    Votes: 161 6.1%
  • above 250000
    Votes: 142 5.4%
  • Total voters
    2,652
4th gen wheels on a 2nd gen ram
A new approach to the well known front end problem
Just turned 100K on my 2001. Had the clock spring replaced under recall and the lift pump replaced both at around 70K. No other problems other than an intermittent headlight switch and intermittent hard starts (two or three cranks on the starter).
Wow, that year since my last post on this went fast!! 173,000 on the '99 truck and the '01 is settin in my drive at 99,999. I think I am my own warranty station on both trucks now. No worries. :)
105,000 on my '99
Replaced lift pump and injection pump 98,000 miles (2 months out of warranty)
MAP sensor at 104,000
brake pads and shoes at 80,000
rear axle seal leaking now - needs replaced
227,xxx with the transmission being the only "need to replace" item at 204,xxx, and only after numerous other power adders, put in the Air dog at probably 190,xxx, and we upgraded the VP-44 to a hot one for more juice at 224,xxx, though I think the original still had a fair bit of life left in her yet. Damn solid truck.
211k and going strong, 2 LPs, original VP, auto trans original and still working fine. Power seat is acting up and the AC quit cooling last month.
Miles...
Yeah, lets see. '05, 2500 w/ 784 miles total. That was all I was able to put on it before I deployed and have been over here eversince. I wonder how its doing just sitting there in my garage?
currently 113+ on mine...
Crowboy i would think the cummins is just fine unless you have someone at home to drive it a little bit each week, as long as some kind of fuel stabilizer was put in the tank the fuel should be fine, Just when you get back home check the fuel, fuel filter... worst case you have to change fuel filter and drain tank and put in fresh fuel.
