Hey JKloppe,
Can you explain more on the wiring? Your picture shows the blue wires coming off of the resistors and plugging into the back of the aluminum plate--what are they plugging into? Also, are the resistors wired for both high and low? It appears that the resistors are grounded--am I looking at it correctly? I plan to do the harness separately for each side since we are blessed with 2 batteries. I am working on a Bi-xenon projector setup and would like your suggestions on wiring them up with resistors and diodes to keep the low beams activated when the highs are switched on to activate the solenoid. My truck is an 05--so no CAN-BUS. Wiring should be same as yours. Do you have any wiring diagrams you used? Thanks. .
