Hum... . good stuff except I wasn't talking about sustained HP and neither were they, what was talked about was having enough air to burn the fuel required to make that much power.
I doubt HX-35 will not support 350 HP from what I've seen.
Even with my Twins at 60 psi I'd doubt it would support much more than 550 at 1300 degrees which you could hold for any time without the water getting hot, 1100-1150 might be a better number.
I don't do Maps or stuff like that, I'm too much of a Mechanic and common sense thinker..... if it works, use it, if it's too hot, back out, if your loosing, stay in it
Jim
Jim
