Inverter location
Another DEF failure (Maybe)
Front axle center shaft
I recently discovered that the 110 plug on my dash is not working. Can anyone tell me where the inverter is located or what to start looking for as far as troubleshooting. I rarely use it, so I don’t really know how long it’s been out. I did have the dash and everything else out of the truck last year for an HVAC repair so it could be something as simple as a disconnection.
Craig
The Power Distribution Center (PDC) is located in the engine compartment near the battery. This center contains cartridge fuses and mini fuses. A description of each fuse and component may be stamped on the inside cover, otherwise the cavity number of each fuse is stamped on the inside cover that corresponds to the following chart.
No more pdf uploads it appears, here are some screenshots.
