The sercive tech at cummins will want your engine serial number also. The tag is located on the front drivers side of the engine. Had mine go about a month ago. You may also want to try to reset your APPS, by disconnecting your battery cables, reconnecting them, turning key to on, slowly depress acc. pedal to floor and then slowly release. This resets the parameters the ECM reads from the APPS
