The ambient temperature was 45 and the battery voltage was 12.6 before I started the test.
I disconnected the grid heaters and started the truck. The voltmeter went right up to the top end of the normal range or about 14 volts
With the headlights and fan on, the voltage stayed at 14 based on the dash board voltmeter.
I took the truck on a 20 mile drive at highway speeds. The voltage stayed at 14 for the drive
When I got home, I reconnected the grid heaters, restarted the engine and voltage was at 14 on the instrument panel. At this point, I measured with the digital Fluke and the battery was 14.6 and the alternator was a t 14.8.
Driving the truck again, the voltage on the instrument panel stayed at 14
Thank you for your patience.
