Engine/Transmission (1994 - 1998) Long crank
2nd Gen Non-Engine/Transmission My 1996 2500--if it were you...
2nd Gen Non-Engine/Transmission Need AC help
So I have noticed that my 12-valve takes a while to actually fire over. Cold, hot, sitting for three hours or for two seconds, it doesn't matter.
If I blip the throttle as I start to crank, it fires instantly - as in less than one revolution and it's running.
Would this be an idle speed adjustment? I haven't put an optical tach on it, but the one in the dash seems to indicate it's running in the ballpark (warm, A/C on, in gear, blah blah blah). Or is it another adjustment?
I've been working on and off on a customer's '87 and it lights off without any throttle input. Granted it's a totally different setup, but I have known other guys with p-pumps that fire up like that too.
Likely need to turn the idle up a bit. I run mine down in the low 700 rpm range and just hold the fuel peddle down a bit instinctively when cranking. Fact is it starts better and builds vac quicker (necessary for brakes, critical when doing low speed work with trailers on a hill) if the idle is in the 900 to 1200 rpm range.
If you're working on a 87 Cummins Dodge, it's a conversion since they didn't hit the dealerships till 89. Some interesting desirable 4 door conversions are around.
No vacuum brakes here, hydroboost on mine and that other rig. Only things running on vacuum on mine is HVAC controls and cruise.
The other truck is a 76 chevy crew cab long bed dually. It's got an 87 heavy duty engine in it, an allison trans (a real one, not one of the POS duramax ones), a gear splitter, an original kelderman rear air bag, and a lot of farmer engineering. It's got a hydroboost setup as well, but because it's got a school bus/straight truck engine, no vacuum pump. The power steering pump bolts to the timing case directly.
