I was able to sneak out to my truck to test pull the MAP sensor connection test:
A-B = 0. 1 V dc
A-C = 2. 9V initially and bled down to . 2V upon DMM connection
B-C = 5. 0V dc
Does the A-B connection indicate a wiring harness issue? I wasn't able to pull the ECM plug at this time.
Nich,
It sounds like maybe you could be confusing the sockets on the MAP sensor connector.
Orange wire -> Socket A = 5v Supply
Black/Lt. Blue wire -> Socket B = Ground
Grey/Red wire -> Socket C = MAP Signal
As mentioned before, with the ignition ON, you should have 5 volts between sockets A and B. It sounds like you did, but possibly you thought you were measuring pins B and C instead? I don't see any other way you could measure 5 volts at the MAP connector... unless something is really screwed up with the wiring.
Measuring 5 volts at the MAP sensor connector is only half the battle though. To verify you don't have something wrong with the wiring harness, you really need to check for continuity (an unbroken connection) between socket C of the MAP sensor connector and the ECM connector. To do this you'll need to disconnect the 50-pin connector at the ECM and figure out which socket there is number 8 (Hint: follow the grey / red wire into the ECM connector and count the sockets from the corner).
If everything checks out with the wiring harness, then you could either really have very low boost pressure which can trigger the P0237 DTC, or the ECM is bad.
Do you have a gauge installed to verify the boost pressure?
Keep us posted,
John L.
