I'm stumped. I pulled off the AFC and went for a test drive but only got a little more smoke and power. EGTs still quickly reach near 1,600 degrees and boost just 33 psi. So I think that rules out a problem with the AFC. Before I had my head replaced and ported with a custom intake manifold and elbow my truck had dyno'd well over 500 hp reaching over 47 psi boost, cleaning up much of the smoke and EGTs near 1,500. I've solved oil and boost leaks but still can't get the truck to run any better.
I've adjusted the 100 plate, Star Wheel, and AFC fully forward. Pre-boost fuel screw is also fairly far forward, I backed it out after putting it further forward because it was hazing heavily at idle. The mechanic who did the work had made some major mistakes and I don't know what else he did for tuning, it was over my head. On one test drive we made 42 psi and 1,400 EGTs but power felt weak with no smoke so he made adjustments for more power but never got that much back, not even 32 psi and he said he wasn't sure what the problem was.
I now have lots of smoke, the mid range cleans up a little better but is still heavy. Mid range power is pretty strong. When it gets to 30 psi it feels as though the engine is being choked, no more boost but tons of smoke. The wastegate line on the turbo is pinched so it should be capable of much more boost to clean up the smoke and make more power. I've tried turning everything back and had very little power, 19 psi and 1,100 degrees, still very noticeable smoke. Truck runs much better with everything forward.
I've checked the governor arm and when I move the throttle by hand with the fuel lever in the run position, it hits just above the bottom of the plate at just over 1/2 throttle and slides up very smoothly. Definitely not getting stuck under the plate. I also had my local mechanic help me check and adjust my throttle linkage to make sure I'm getting full fuel and I am.
What else should I check? Fuel filter is only a few months old. Lift pump leaks only when being primed. I'm obviously getting tons of fuel with the heavy black smoke and I see no drops on the ground. Power kicks in right at 7 psi and mid range is good until about 24 psi boost. Like I said, can't find any boost leaks but what is a good method for finding a boost leak that can't be seen? I had drivability issues that were solved with a valve adjustment. I'm at a total loss as to what else could be wrong. Suggestions?
Thanks,
Matt
Thanks,
Matt
